LCDriver S/ware help!!!!!
threx666
hey guys,
im just a newbie starting to explore some mods and needs your help plssss
does anyone of you here still have the LCDriver software by Uller before?
i tried to d/l it thru its link but no dice man.
pls pls pls bros help me !!
can point me to some link or better yet can some kind soul pls spare me a copy ?
here is my addy , threx666@yahoo.com.sg
thanx in advance bros:)
LCDriver was cool in its time, but there are lots of lots better programs out there. Is there a specific reason you need LCDriver?
What LCD do you have?
threx666
hi bro
im using a natrium tech lcd panel (HD44780)20x4 display
i can not find a driver for it,i remember i used the LCDriver s/ware to set the BAud rate,the port it uses and the the no.of columns and rows for my lcd.
i was able to set it up on my prev rig but now that i waas using my newer(?)rig i cant seem to set it up properly
i tried a lot of s/ware /drivers but it seems that i am not doing it correctly or it does no work at all,the display just shows some garbled messages like the whole display shows a whole string of @@@@ strings for the whole 20x4 lines.
or when i tried some s/wares it shows some letters and numbers on random position!
help pls bro
its using a 9 pin connector so i assuming its a serial connection ?sorry iseem to be confuse between the 2!haiizzz
help plz:confused:
I poked around on the WayBackMachine and found this EXE:
  • LCDriverInstaller.exe
