LCD Not Working
girlpantz
I bought the "CFAH1602B-TMC-JP" LCD the other day in blue - backlight and am connecting it to a parallel cable. I know parallel questions are not generally answered here but it's more to do with the LCD. I wired all 16 pins up correctly and can get the backlight to come on but that is it - I cannot get the 16 x 2 lights to work. I see on one side of the display that there is A and K, each having 2 pins - what are these for and should I connect another 4 wires to them? Really I need to know just how to get power to these lights.
Hope you can help.
You need to check the data sheet for the backlight current and voltage, and then use this thread as a guide to calculate the backlight resistor.
girlpantz
I can get the backlight working by connecting 5V to Pin 15 and GND to Pin 16. However, I cannot get the 32 individual character displays to come on. Is there something I should be connecting to these?
> . . . connecting 5V to Pin 15 and GND to Pin 16 . . .
This will likely damage the backlight.
As far as connecting a CFAH* to a PC, about all we can offer is:
Check your wiring, again. :(
Good wiring guides for HD44780 compatible LCD's can be found:
http://www.overclockers.com.au/~mwp/cc/guides/setup-hd44780.htm
http://www.myrolypoly.com/lcd_project/lcd_project.html
http://www.icehw.net/article.asp?id=104
http://www.geocities.com/ResearchTriangle/1495/ee_lcd.html
http://www.overclockers.com.au/techstuff/a_diy_lcd/
http://www.hardforum.com/showthread.php?threadid=248302
You can also go to http://forums.bit-tech.net/showthread.php?threadid=5582 and search for "assuming alphanumeric" and you will find a short Q/A post on parallel displays.
girlpantz
OK. Thanks for the links.
Just one last thing though... can you tell me what pins "A" and "K" are for?
Thanks.
