jdg date & time formatting plugin stopped working as of latest release
meklubba
I am using the plugin jdg_time.dll to format date and time in a personal way (yyyy-mm-dd hh:nn:ss). The plugin does not work after the upgrade to CC2 version 20060216. I noticed that there is a plugin called cc2_jdg_time.dll, but it does not work either. I only get the famous [E01]. :)
Anyone had the same problem? Anyone know how to solve it, perhaps the original plugin author?
Thankfull for any suggestions,
Daniel
EDIT: Using Process Explorer from Sysinternals I saw that the jdg_time.dll is not loaded by cc2_service.exe, only the cc2_jdg_time.dll is.
"cc2_jdg_time.dll" is the same file as "jdg_time.dll", its just been renamed so itll load with the newer version of the cc2 service.
The problem you are having is caused by the plugin looking for "cc2_time.ini" instead of "jdg_time.ini".
So if you load a screen that uses the plugin, youll need to go into the CC2 directory and rename "jdg_time.ini" to "cc2_time.ini".
Restart CC2 and it should then work.
meklubba
Ok, here is the deal. :)
cc2_jdg_time.dll looks for the ini file cc2_time.ini.
For consistency reasons I renamed both the cc2_jdg_time.ini to cc2_time.ini and cc2_jdg_time.dll to cc2_time.dll. After changing in the screen file to use the right ini file it did the trick.
However, the cc2_jdg_time.dll shipped with this release of CC2 is one of the previous jdg_time.dll with the month value bug in it, see https://forum.crystalfontz.com/showthread.php?s=&threadid=3554.
So in order to get it all to work, here is what you need to do.
1. Go to the thread mentioned above and download the latest jdg_time.dll.
2. Rename it from jdg_time.dll to cc2_jdg_time.dll, in order to get it loaded by cc2_service.exe.
3. Put it in the CrystalControl2 directory, replacing the existing one.
4. In your screen files refer to jdg_time.ini, since the jdg_time.dll still looks for it, use from="jdg_time.ini".
(After installing version 20060216 there was a jdg_time.dll as well in the CrystalControl2 directory, but since I didn't know what version it was I deleted it.)
When this is done and up and running you should have 3 files:
cc2_jdg_time.dll
jdg_time.ini
jdg_time.log
Perhaps someone is able to rebuild the jdg_time.dll and rename it to cc2_time.dll and let it look for the cc2_time.ini file and use the cc2_time.log log file in order to avoid confusion. :)
Daniel
I didnt notice that, nice find.
No one can fix this except jdgordon who doesnt seem to frequent these forums too much anymore.
Im considering building the ability to format time & date into my "cc2_timedate" plugin.
meklubba
No problemo. :)
I realised that too.
It would be nice to get that functionality. The fewer plugins the better (at least with similar functionality :) ).
I have added support for customizable date/time information to the official cc2_timedate plugin.
It uses a different format, so screens distributed with CC2 that use the JD plugin have been updated to use cc2_timedate.
The plugin and updated screens will be in the next release.
meklubba
Great! :D
It is not that much of a problem to alter the formatting, the screen files must be updated to use the timedate-plugin anyway.
Many thanks!
/Daniel
Itll use this format (strftime):
%a
Abbreviated weekday name
%A
Full weekday name
%b
Abbreviated month name
%B
Full month name
%c
Date and time representation appropriate for locale
%d
Day of month as decimal number (01 – 31)
%H
Hour in 24-hour format (00 – 23)
%I
Hour in 12-hour format (01 – 12)
%j
Day of year as decimal number (001 – 366)
%m
Month as decimal number (01 – 12)
%M
Minute as decimal number (00 – 59)
%p
Current locale's A.M./P.M. indicator for 12-hour clock
%S
Second as decimal number (00 – 59)
%U
Week of year as decimal number, with Sunday as first day of week (00 – 53)
%w
Weekday as decimal number (0 – 6; Sunday is 0)
%W
Week of year as decimal number, with Monday as first day of week (00 – 53)
%x
Date representation for current locale
%X
Time representation for current locale
%y
Year without century, as decimal number (00 – 99)
%Y
Year with century, as decimal number
%z, %Z
Either the time-zone name or time zone abbreviation, depending on registry settings; no characters if time zone is unknown
Percent sign
