Do keep in mind that the speed is really a non-issue. The bounding factor with either the serial or parallel LCDs is the response time of the fluid--not the interface transfer rate. A serial LCD operating at 19200 baud can update the entire screen of a 20x4 at 24 frames per second, which is 41mS per frame. The response time of the LC fluid is typically around 100mS to 150mS.
