If I wanted to change the Color...
Ferrari355
I have the CFA634-TFB-KU Display.. If I were to turn the film around would it become the Dark blue background with White Text?
First the disclaimers:
1) we do not reccomend you try this
2) it will void your warranty and we would not be too excited about doing any out-of-warranty repair
Now for the practical . . .
I do not remember for sure, but as I recall the film has to be rotated 90 degrees, not 180 degrees. This means that you would have to find a larger sheet, or there would be some "seams".
The rear polarizer in the TFB is transflective, that means it is designed to TRANSmit light from the backlight, plus be reFLECTIVE for light coming from the front. The reflective property will block some portion of the light from the backlight.
The rear polarizer on the TMC is reflective, to let as much light as possible through. This is so because the negative mode does not let much light in from the front anyway, so the usefulness of the backlight is maximized by using a rear transmissive polarizer.
The end result is that the backlight will be a little dimmer.
Another thing to be aware of is that the front polarizer on the TFB is a "FSTN". The front polarizer on the TMC is "STN" so you may not get the same color as a TMC if you re-use the polarizer.
Appel
Just for giggles, I tried this with a plain ol' calculator once - not a transflective screen- and indeed the screen was black with white numbers....
Ferrari355
question who sells polarising film? both my LCD's the color I want the film has to be rotated 90 degrees and that's just not going to work out with my 20x4.
I guess I would need to find a wide enough sheet that would work sideways 90 degrees to cover the display.
Ferrari355
I am sure the LCDs and linear material are compatible.
Thanks one question I have.. I was messing around with a display I have, with the background so dark like this would anything be visible or would I have to make it a tad lighter?
The backgrounds can be pretty dark:
phpThumb.php
You do not want to make it anything other than "optimal". Typically we pull the front polarizer off the glass, reassemble the module, then experiment with candidate polarizers and angles. Once there is a good one, mark the angles, trim it and reassemble it.
