How to SAVE SCREEN in Screen Editor?
That is 1 thing you can not do at this time. Hopefully, this will be incorporated in a future release.
wiszmaster
really?
is there a manual way to doing this? I'd like tomake at least a backup of the screen file - how do I do that?
marco
What is in the screen? If is similar to an existing screen, make the text file yourself.
Or tell me what is in it (pix would be nice, also), and I could probably do it.
wiszmaster
jc,
Thank You for the offer. I will try to write it up.
--marco
wiszmaster
JC,
If i posted up the cc2_service.ini, would that do the job? it seems like all of the screen info is in there?
thank you,
--marco
wiszmaster
cc2_service.ini
[general]
windows_start=1
dim_idle_time=1800000
dim_to_pct=16
[m00]
id=2649597340
module_name="Crystalfontz 634"
options=0
screen_sel=0
alt_enabled=1
brightness=100
contrast=75
dkc_disable=0
transition_random=0
transition_length=2951
[m00-s00]
screen_name="AC3 Main Unit"
options=0
alt_delay=20000
[m00-s00-r00]
options=0
scroll_speed=250
[m00-s00-r00-i00]
string="Status: "
options=0
length=0
scroll_speed=0
[m00-s00-r00-i01]
id=605898122
options=0
length=0
scroll_speed=0
[m00-s00-r01]
options=0
scroll_speed=250
[m00-s00-r01-i00]
string="Tank Temp: "
options=0
length=0
scroll_speed=0
[m00-s00-r01-i01]
id=1203001470
options=0
length=0
scroll_speed=0
[m00-s00-r01-i02]
id=764757448
options=0
length=0
scroll_speed=0
[m00-s00-r01-i03]
string="F"
options=0
length=0
scroll_speed=0
[m00-s00-r02]
options=0
scroll_speed=250
[m00-s00-r02-i00]
string="pH: "
options=0
length=0
scroll_speed=0
[m00-s00-r02-i01]
id=1807317377
options=0
length=0
scroll_speed=0
[m00-s00-r02-i02]
string=" ORP: "
options=0
length=0
scroll_speed=0
[m00-s00-r02-i03]
id=3600690692
options=0
length=0
scroll_speed=0
[m00-s00-r03]
options=0
scroll_speed=250
[m00-s00-r03-i00]
id=1112400219
options=0
length=0
scroll_speed=0
[m00-s00-r03-i01]
string=" "
options=0
length=0
scroll_speed=0
[m00-s00-r03-i02]
id=1731734103
options=0
length=0
scroll_speed=0
[m00-s01]
screen_name="AC3 PX1000"
options=0
alt_delay=20000
[m00-s01-r00]
options=0
scroll_speed=250
[m00-s01-r00-i00]
string="Status: "
options=0
length=0
scroll_speed=0
[m00-s01-r00-i01]
id=3203627821
options=0
length=0
scroll_speed=0
[m00-s01-r01]
options=0
scroll_speed=250
[m00-s01-r01-i00]
options=0
length=0
scroll_speed=0
[m00-s01-r01-i01]
id=3364948018
options=0
length=0
scroll_speed=0
[m00-s01-r01-i02]
id=2143204366
options=0
length=0
scroll_speed=0
[m00-s01-r01-i03]
string="F"
options=0
length=0
scroll_speed=0
[m00-s01-r02]
options=0
scroll_speed=250
[m00-s01-r02-i00]
string="pH: "
options=0
length=0
scroll_speed=0
[m00-s01-r02-i01]
id=1014421362
options=0
length=0
scroll_speed=0
[m00-s01-r03]
options=0
scroll_speed=250
[m00-s01-r03-i00]
id=1112400219
options=0
length=0
scroll_speed=0
[m00-s01-r03-i01]
string=" "
options=0
length=0
scroll_speed=0
[m00-s01-r03-i02]
id=1731734103
options=0
length=0
scroll_speed=0
[m00-s02]
screen_name="jc_curr_rssweather-txt2"
options=0
alt_delay=20000
[m00-s02-r00]
options=10
scroll_speed=250
[m00-s02-r00-i00]
id=873389220
options=0
length=0
scroll_speed=250
[m00-s02-r01]
options=10
scroll_speed=250
[m00-s02-r01-i00]
id=2339548644
options=0
length=0
scroll_speed=250
[m00-s02-r02]
options=10
scroll_speed=250
[m00-s02-r02-i00]
string="H:"
options=0
length=0
scroll_speed=250
[m00-s02-r02-i01]
id=736535469
options=0
length=0
scroll_speed=250
[m00-s02-r02-i02]
string=" HI:"
options=0
length=0
scroll_speed=250
[m00-s02-r02-i03]
id=4169285295
options=0
length=0
scroll_speed=250
[m00-s02-r02-i04]
string="F"
options=0
length=0
scroll_speed=250
[m00-s02-r02-i05]
string=" WC:"
options=0
length=0
scroll_speed=250
[m00-s02-r02-i06]
id=2971940253
options=0
length=0
scroll_speed=250
[m00-s02-r02-i07]
string="F"
options=0
length=0
scroll_speed=250
[m00-s02-r03]
options=10
scroll_speed=250
[m00-s02-r03-i00]
string="W: "
options=0
length=0
scroll_speed=250
[m00-s02-r03-i01]
id=418425454
options=0
length=0
scroll_speed=250
[m00-s02-r03-i02]
string=" @ "
options=0
length=0
scroll_speed=250
[m00-s02-r03-i03]
id=1612694900
options=0
length=0
scroll_speed=250
wiszmaster
Screen 1:
Screen 2:
Status:_<from file>
Tank Temp:_<from file>[*]F
pH:_<from file>_ORP:_<from File>
DATE_TIME
Status:_<from file>
pH:_<from file>
DATE_TIME
I do need to know some additional info. There are several id=xxxxxxxx's. The info for these id's are in other ini files. If you could zip all the ini files in the cc2 directory and post here, this would (or should) give me the rest of the info needed to make some screen files.
BTW, I'm not doing anything with the weather file. You can simply open up the screen file and copy/paste your location info directly there. OK?
JC
yep, 1 more thing.... I need a copy of your ACTank.txt file. Just to test to make sure what I come with does what it supposed to do.
Also, if you want to, give me a description of what all this does/comes from. If you don't mind, I would post the these screens in the User Screen Libray. I would need info on how you produce the text file, also.
wiszmaster
JC,
This is a "remote" display for an Aquarium Controller.
NeptuneSystems AC3 (www.neptunesys.com)
Someone else wrote a script using Macro Scheduler to telnet to the device, and perform a "stutus" request, capture the data from the telnet response, and parse it into the ACTank.txt
ACTank.txt:
[READINGS]
STAT=NORMAL
TEMP=82.0
PH=7.99
ORP=429
COND=--.-
[PX1000]
PX1_1=80.8
PX1_2=8.10
here is the link for the Official Thread of the build on ReefCentral
http://reefcentral.com/forums/showthread.php?s=&threadid=1219081
marco
wiszmaster
I will try that file in ajust a minute, need to switch to to the windows machine (my main machine is OSX)
This is for a saltwater reef tank. I'll send you a PM with a link to my setup :)
Which files should I backup, just i case the screen files don't work proper on my setup?
thanks,
marco
No need to backup. Don't delete any of your current screens. Just add the new ones. If the new screens don't work, just delete 'em (but they should work fine).
wiszmaster
JC,
sorry for the lack of response - i did not get around to checking the file over the weekend - I've had the screen apart as I'm trying to make a frame for the drive bay bracket - this one is going to be mounted on the wall.
I should be able to test it tomorrow i hope.
--marco
wiszmaster
I finished my LCD screen project tonight!
This is a remote screen for my AquaController 3 - it shows Temp, Temp#2, PH, PH#2, If the unit has an alarm, if it's in maintenance mode ..the ORP .. etc..etc.. ... here are my pics:
