How to power VBT on OLED?
tinhead
I'm reffering to the CFAP2002A-Y-JCV.
Power via Resistor or Voltage-regulator?
Does the current-draw and intensity vary with the ammount of pixels on?
If so, should VBT be powered by a voltage-regulator (2.0-3.0V, ~30mA or more?), or will 5V via a resistor of 75 to 125Ohm(?) do the trick?
If the intensity varies, could I burn out a single pixel by applying 3v and something like 25mA?
Thanks in advance!
tinhead
tinhead
No reply it seems..
I have found some info on my own, the current does change in realtion to the ammount of lit pixels.
ie. a voltageregulator would probably be a good bet to get a nice and even output.
One question does however remain: If a resistor is used, could one burn single pixels as described above?
Sorry for the delay in replying.
I need to run some tests myself to understand it better myself. I almost think that there was a regulator on the board . . . but I'm not sure.
I'll have to hook one up or contact the factory engineer to be sure.
tinhead
No worries :)
I have found a display that seems similar to yours here (it's in german but look at page 3). They seem to use a 1kOhm resistor or a 5k+25kvariable from +5v to power Vbt.
Might it be something similar?
If you could clarify this more I'd be really glad! :)
Pyrofer
I used the PLED screen to replace an LCD and pretty much just soldered it onto the old LCD connector.
I used a 10k VR between 5v and GND (the same one that I used for contrast on my LCD) to run Vbt.
5v________________________
|/____ Vbt
0v---------------------------------------
Is this going to burn out my display? I seem to get a good range of control on the brightness of the display and have it turned down quite a way from the brightest it can go.
Well, these displays are meant to be "drop-in" LCD replacements, so I am not surprised that they worked fine that way.
As long as you do not wun the brightness too high (there is a brightness vs. lifetime tradeoff) then you should be fine with your circuit.
