Help with CC and Dlportio...
Worlock
After a recent format (on WinXP) I can't seem to get CC to work. Even though she worked fine before the format. It keeps telling me that dlportio.sys device driver not loaded. I've reinstalled both CC and port95nt to no avail ( I did install port95nt and it reports no errors). I've even tried the new beta CC soft, to see if that may help but I'm still not having any luck.
I've tried to register the .DLL's manually from the console via the regsvr32.exe command, but it says that "dlportio.dll was loaded, but the DllRegisterServer entry point was not found. This file cannot be registered."
Any help on this would be greatly appreciated.
The next version of CC wont use DLPortIO so that should fix your problem.
[edit]
Is avaliable now.
Worlock
Outstanding! I installed it and it says "Privilaged instruction" over and over then terminates. This has got to be somethign with my machine...
Worlock
Not on load no, but that's only because I don't have anything loaded in the config... once I load my LCD info it poofs...
