help needed now
unckekev
ok since no one will tell me what cable i need lets try somthing else.
What do i need to get started. i have the CFAH2002A. Now what do i need to get it on my PC
unckekev
like im gon to put the 10k pot in to adjust contrast. But do i need any other resistors. Can someone at least tell me this!
We do not offer end-user tech support on the CFAH*, CFAG* or CFAP* series modules in PC applications. We will not accept returns on CFAH*, CFAG* or CFAP* modules damaged in an attempt to connect them to a PC.
The serial/USB modules and kits (634, 633, 632 models and kits: http://www.crystalfontz.com/products/select_kit.html) are best suited for PC applications.
Please see this forum thread for our PCuser LCD recommendations:
https://forum.crystalfontz.com/showthread.php?s=&postid=1922
However, good wiring guides for HD44780 compatible LCD's can be found:
http://www.overclockers.com.au/~mwp/cc/guides/setup-hd44780.htm
http://www.myrolypoly.com/lcd_project/lcd_project.html
http://www.icehw.net/article.asp?id=104
http://www.geocities.com/ResearchTriangle/1495/ee_lcd.html
http://www.hardforum.com/showthread.php?threadid=248302
You can also go to http://forums.bit-tech.net/showthread.php?threadid=5582 and search for "assuming alphanumeric" and you will find a short Q/A post on parallel displays.
