hd44780 part of screen dead
thefamilyman
Help me plaese...
i have a hd44780 20*4 screen that use to work fine, but then one day it decided not to work correctly :~
the test screen works fine, but when data is applied into it the first 8*2 pixels dont work...
the wireing is all correct.
the first pic is the 'boot' screen and it shows that the pixels do work, but the second pic shows a full screen on 'w's but the first 8*2 doesn't display.
thefamilyman
ah sorry... i should of included more info :p
its currently connected to my pc via parallel port, using
DriverLINX Port I/O Driver to access the port and using LCD Smartie5.2 or LCD center 2.0 to drive the LCD screen.
yes CFAH_WinTest does talk to it and when done the 20*4 8bit test on the correct port, it will disply all the characters except fot the 8*2 block.
it is conected to pc via this interface
http://www.pmb.co.nz/products/lcd_4a5/lcd_4a5_1.htm
thanks.
