Just registered for a question: I'm planning to place an order for the 633 serial blue/white LCD kit. But was curious: I have an Asus A7N8X Deluxe motherboard which has the COM2 port as an onboard header (its normal place on the backplate is occupied by 5.1 speaker jacks) for an add-on DB9 socket. But, looking at the catalog's rear shot of the module, the 2x5 column of pins is the serial interface, I assume? So would it then be possible to just connect the 633 directly to the motherboard using a 10-pin ribbon (i.e. similar to #WYR232Y08, but w/ 10-pin-header connecters on each end)? BTW: Need serial because COM1 & all six of my USB ports are in use.
