Hi, I wired up the cfag12864b-TMI-V and used the same test bench for the cfag12864b-WGH-N#. The WGH-N# didn't even turn on. I thought the same board and components were used for both LCD's. After comparing the boards, I noticed that the WGH-N# model does not have the U4, C1, C2, A10, JE, and Q1 components. Also, the cfag12864b-WGH-N# is not turning on with the typical Vo connections for the display contrast.
What are your suggestions for powering the display contrast for the cfag12864b-wgh-N? I did a continuity test and found out that the LCD turned on as soon as I tested for pins 3 and any combination of it with pins 4-16. Also, it turns on when I test pins 3 and any combination of 1 or 2.
Do you have a data sheet or schematic that shows what the missing components do?
I know you don't support connecting the LCD's to the parallel port, but how could I wire the cfag12864b-WGH-N# into the parallel port? Is it the same as the TMI-V wiring?
Thanks for your time.
