Have been using a 634 LCD for some time now, but with older
versions of Crystal Control (092) and MBM (5.07). Everything
has been working, except for not being able to see the fan
speeds thru the CC s/w (and yes, it does show up in MBM).
Decided to do a clean install of Win98 and use the newer
versions of CC and MBM ( no choice here). Got the s/w loaded
and the screens set up and everythings rockin' along. Fan
speeds even showed up.
Then, I noticed that the router and switch "act/link" lights
were going crazy; as if data was being transfered between
all three systems at the same time. Cable modem "data"
light was not lit, so I had to conclude nothing was being
sent out over the net to someone.
Started shutting down programs and once I shut down
Crystal Control, the "activity" stopped. Started it back up and
the "activity" began again.
Left Crystal Control running and disconnected the mapped
drives to one of the other systems. "Activity" ceased to that
one particular system. Disconnected the remaining mapped
drives to the other system and all was quite.
So, what has changed in either MBM or Crystal Control 096
to cause this behavior ??? Has to be something as no other
new hardware or software was installed after the clean
install of Win98.
thanks
scsiguy
install of Win98.
thanks
scsiguy
