creating the crc
jeremy
I am trying to figure out the 16 bit crc using perl.
Does anyone have an idea where to start?
norm
java version of CRC
im having trouble re-creating the CRC16 using java. do you have a working example you could email me. thanks.
--norm
I don't have a working example for Java, but if I were to go about it, I'd just port the C code to Java, which ideally wouldn't be much of a problem at all, since the syntax is so similar.
norm
java crc
i did that and have different CRCs. here is the source...
public class CRC16 extends Object
  public static void main(String[] args)
    byte[] data = new byte[2];
    data[0] = 0x01;
    data[1] = 0x00;
    System.out.println(get_crc(data ));
    System.out.println(Integer.toHexString(get_crc(data)));
  public static int get_crc(byte[] data)
    //CRC lookup table to avoid bit-shifting loops.
    int[] crcLookupTable =
      {0x00000,0x01189,0x02312,0x0329B,0x04624,0x057AD,0x06536,0x074BF,
       0x08C48,0x09DC1,0x0AF5A,0x0BED3,0x0CA6C,0x0DBE5,0x0E97E,0x0F8F7,
       0x01081,0x00108,0x03393,0x0221A,0x056A5,0x0472C,0x075B7,0x0643E,
       0x09CC9,0x08D40,0x0BFDB,0x0AE52,0x0DAED,0x0CB64,0x0F9FF,0x0E876,
       0x02102,0x0308B,0x00210,0x01399,0x06726,0x076AF,0x04434,0x055BD,
       0x0AD4A,0x0BCC3,0x08E58,0x09FD1,0x0EB6E,0x0FAE7,0x0C87C,0x0D9F5,
       0x03183,0x0200A,0x01291,0x00318,0x077A7,0x0662E,0x054B5,0x0453C,
       0x0BDCB,0x0AC42,0x09ED9,0x08F50,0x0FBEF,0x0EA66,0x0D8FD,0x0C974,
       0x04204,0x0538D,0x06116,0x0709F,0x00420,0x015A9,0x02732,0x036BB,
       0x0CE4C,0x0DFC5,0x0ED5E,0x0FCD7,0x08868,0x099E1,0x0AB7A,0x0BAF3,
       0x05285,0x0430C,0x07197,0x0601E,0x014A1,0x00528,0x037B3,0x0263A,
       0x0DECD,0x0CF44,0x0FDDF,0x0EC56,0x098E9,0x08960,0x0BBFB,0x0AA72,
       0x06306,0x0728F,0x04014,0x0519D,0x02522,0x034AB,0x00630,0x017B9,
       0x0EF4E,0x0FEC7,0x0CC5C,0x0DDD5,0x0A96A,0x0B8E3,0x08A78,0x09BF1,
       0x07387,0x0620E,0x05095,0x0411C,0x035A3,0x0242A,0x016B1,0x00738,
       0x0FFCF,0x0EE46,0x0DCDD,0x0CD54,0x0B9EB,0x0A862,0x09AF9,0x08B70,
       0x08408,0x09581,0x0A71A,0x0B693,0x0C22C,0x0D3A5,0x0E13E,0x0F0B7,
       0x00840,0x019C9,0x02B52,0x03ADB,0x04E64,0x05FED,0x06D76,0x07CFF,
       0x09489,0x08500,0x0B79B,0x0A612,0x0D2AD,0x0C324,0x0F1BF,0x0E036,
       0x018C1,0x00948,0x03BD3,0x02A5A,0x05EE5,0x04F6C,0x07DF7,0x06C7E,
       0x0A50A,0x0B483,0x08618,0x09791,0x0E32E,0x0F2A7,0x0C03C,0x0D1B5,
       0x02942,0x038CB,0x00A50,0x01BD9,0x06F66,0x07EEF,0x04C74,0x05DFD,
       0x0B58B,0x0A402,0x09699,0x08710,0x0F3AF,0x0E226,0x0D0BD,0x0C134,
       0x039C3,0x0284A,0x01AD1,0x00B58,0x07FE7,0x06E6E,0x05CF5,0x04D7C,
       0x0C60C,0x0D785,0x0E51E,0x0F497,0x08028,0x091A1,0x0A33A,0x0B2B3,
       0x04A44,0x05BCD,0x06956,0x078DF,0x00C60,0x01DE9,0x02F72,0x03EFB,
       0x0D68D,0x0C704,0x0F59F,0x0E416,0x090A9,0x08120,0x0B3BB,0x0A232,
       0x05AC5,0x04B4C,0x079D7,0x0685E,0x01CE1,0x00D68,0x03FF3,0x02E7A,
       0x0E70E,0x0F687,0x0C41C,0x0D595,0x0A12A,0x0B0A3,0x08238,0x093B1,
       0x06B46,0x07ACF,0x04854,0x059DD,0x02D62,0x03CEB,0x00E70,0x01FF9,
       0x0F78F,0x0E606,0x0D49D,0x0C514,0x0B1AB,0x0A022,0x092B9,0x08330,
       0x07BC7,0x06A4E,0x058D5,0x0495C,0x03DE3,0x02C6A,0x01EF1,0x00F78};
    //Initial CRC value is 0x0FFFF.
    int newCrc = 0xFFFF;
    for (int i = data.length -1 ; i > -1; i-- )
      int lookup = crcLookupTable[(newCrc ^ data[i]) & 0xff];
      System.out.println(lookup);
      newCrc = (newCrc >> 8) ^ lookup;
      System.out.println(newCrc);
    return newCrc;
norm
i was messing with the command byte, data[0]. <br>
if you use a ping as an example...
<pre>
data[0] = 0x00;
data[1] = 0x00;
</pre>
returns .. 0xF0B8
<br>
where the packet debugger in the win example prog gets...
<br>
C=0( 0 = Ping),L=0,D="",CRC=0x0F47
<br>
any help would be apprcaited.
--norm
Sounds like you are pretty close:
0xF0B8 == ~(0x0F47)
So you just need to do a bit-wise invert, so
return newCrc;
should be
return(~newCrc);
norm
u r the man! (or woman)
thanks. i'd google for days on that. i just don't think in hex like i should. when i get a stack for java written you are welcome to a copy.
--norm
norm
spoke too soon
the get hw fw version info command does not return the correct CRC for me
<pre>
data[0] = 0x01;
data[1] = 0x00;
</pre>
returns 0x1ece
<br>
please tell me its another no brainer.<br>
thanks again
norm
working java crc16
tested this...works. java on windows. posted here... liberate as needed.
    // hw - fw
    data[0] = 0x01;
    data[1] = 0x00;
    System.out.println("hw -fw req");
    System.out.println(Integer.toHexString(compute(data)));
    // ping
    data[0] = 0x00;
    data[1] = 0x00;
    System.out.println("ping");
    // reboot
    data[0] = 0x05;
    data[1] = 0x00;
    System.out.println("reboot");
    // clear lcd
    data[0] = 0x06;
    data[1] = 0x00;
    System.out.println("clear lcd");
    // set line 1
    data = new byte[18];
    data[0] = 0x07;
    data[1] = 0x10;
    String text = "Test Test Test  ";
    byte[] textByte = text.getBytes();
    for (int i=0; i < text.length(); i++) data[i+2] = textByte[i];
    System.out.println("text 1");
  private CRC16()
  private static final int[] crcLookupTable =
  public static int compute(byte[] data)
    int newCrc = 0x0FFFF;
    for (int i = 0; i < data.length; i++ )
      int lookup = crcLookupTable[(newCrc ^ data[i]) & 0xFF];
    return(~newCrc);
borak
Do you have an api for c?
What is the use of SimLCD, as I understand it is a simulator of LCD that runs as it without any device and any cables, if yes,
I cant not find the "COM1" mnemonic in available resources
norm
OHHH IIIII..... i,m still ailve....
whatdoyaneed?
i do have a java stack. yes, you don't "need" the device plugged in, build a <a href="http://www.google.com/search?q=serial+loopback&hl=en&lr=&client=safari&rls=en&start=10&sa=N">serial loopback</a>. you do need to install the comm api or an equivielant (serial device support for java).
no i don't have a C api.
--norm
