cpu spikes with 1.0pr3
warrensomebody
I'm running 1.0pr3 build 189 and I'm seeing cpu spikes from CrystalControl that occur about every 40-50 seconds. I'll attach an image of that these look like.
My configuration rotates through 4 screens -- 2 for winamp (title and playtime), 1 for machine name and date/time, and 1 to check my email (I tried disabling this one, but it didn't seem to help).
I use Remote Desktop to log into my media machine, and these spikes often cause my connection to be dropped. I've also noticed that they can make my audio playback stutter.
Please help,
Warren
Try turning of email checking.
Do this by just clearing out your server name from the settings window.
See if that fixes it.
Removing the screen wont stop it from checking for emails.
You have to remove the email server information from the settings window.
pyrotek
check my thread down a bit futher
its prolly the same thing as i had
any update on a fix for this?
pyrotek
warrensomebody
Yes, the email check was my problem. I didn't realize that there was more setup I had done for it in the "Settings..." dialog (the "Email server settings (POP3)" email area). Deleting the email screen isn't enough.
A quick update on this.
The email checking code does use 100% CPU time (nothing i can do about this), but the thread its running in is set at idle priority.
This means that while it does use 100% CPU time, it will not interrupt or slow down other applications or games.
