for wiring these two I think I can use this scheme
, but I'm confused of how to connect the backlights. I want to use a pot to adjust the brightness of the leds, (a 100k I suppose) but I also need to use a resistor, right? Anyone knows which one for the TMI-V and which one for the WGH-N?
I also noticed a difference for the 2 lcd's: for the TMI-V pin 18 it says "negative voltage output", for 19 + and 20 -; for the WGH-N 18, 19 and 20 are "NC". What's the difference??
Any help would be appreciated very much
edit: ok, so for the WGH-N backlight I need an invertor 110-170 V and 400-1000 hz and for the TMI-v the resistor should be around 1.875, right?
