K knowley New member Nov 1, 2005 #21 Not sure, but you'll need speed fan installed to get the temps and fan speeds displayed on your lcd anyway Crystalfontz LCD BlogLooking for additional LCD resources? Check out our LCD blog for the latest developments in LCD technology.
9 '99 New member Nov 1, 2005 #22 Not if you connet temp. probes, and fans to the SCAB module... as I understand it. BTW. Do you have any idea about how long the SATA cables are in SN25P?
9 '99 New member Nov 1, 2005 #23 Oohh did I understand it right, when you said to awoid weekly valueproducts at overclockers.co.uk?
K knowley New member Nov 1, 2005 #24 Oh yeah if you have the SCAB and probes then no need for speedfan. SATA Cables: 30cm should be ample, I've got 45cm ones. http://www.overclockers.co.uk/acatalog/Online_Catalogue_This_Week_Only_25.html is OK!!!! http://www.overclockers.co.uk/acatalog/B_Grade.html AVOID!!!
K knowley New member Nov 1, 2005 #26 '99 said: Thx. Knowley Nice to know what to awoid, when I'm "shopping". Click to expand... Avoid
9 '99 New member Nov 15, 2005 #29 @Knowley.... Do you have any idea, if it is possible to fit a CFA635 and SCAB module into the lowest plastic front on the SN25P?
K knowley New member Nov 15, 2005 #30 Nope... but looking at it I don't see why not, I mean with its fixing plate it conforms to the 5.25" drive form factor, and the space for your DVD drive is smaller. However I've not removed that panel so couldn't tell you what is behind that might get in the way. I'd guess from pictures on the SFF tech forum - http://forums.sudhian.com/messageview.cfm?catid=46&threadid=80601&enterthread=y that the scab module might be too deep.
