I just noticed this problem few days ago. It seems that with the new version of CC2 installed and fan control enabled, my system would freeze if I tries to restart or shutdown. I had the fans set to 70% and when I try to restart or shutdown, it could proceed normally and close everything and exit window, and it would pause there for a bit, until CC2 is closed which I can tell from the fan spinning back to 100% and then after that, the system just hangs there. No reboot or shutdown and the screen is also frozen. Is there a way to correct this problem?
