CFAH4002A-TFH-JP Datasheet inconsistency/question
first of all, thanks for the addition of the other 2 alternative 40x2 displays!
one question i have is regarding the CFAH4002A-TFH-JP datasheet - on section 1 it says its 6oclock, on section 3 it says 12oclock. Which is correct? Is there a 12oclock version?
Also, with the viewing angles, it says vertical is from 10->105 - does this mean CR>2 for 10 degrees below up to 105 degrees below? (i take it this would be hard, given if head on is 0 deg, then 105 would be behind display). Or is this saying 90 is head on, so its effectively -15 (ie 15 above) and 80 below?
Thanks!
Thanks!
