Cfah2004a-ymc-jp
Synapse
If i order one of these do i get a wiring schematic with it?
If not is its HD44780 compatable so i can use one of those freely avail on the internet?
And last question... IF i used LCD Smartie which i prolly wont but its always best knowing....
So do I choose HD44780 Parallel interface or crystalfontz on COM3 (same as my lpt1)
Cheers!!:D
No.
It is HD44780 compatible.
Use any of the HD44780 guide around the net.
HD44780 Parallel.
We do not offer end-user tech support on the CFAH*, CFAG* or CFAP* series modules in PC applications. We will not accept returns on CFAH*, CFAG* or CFAP* modules damaged in an attempt to connect them to a PC.
The serial/USB modules and kits (634, 633, 632 models and kits: http://www.crystalfontz.com/products/select_kit.html) are best suited for PC applications.
Please see this forum thread for our PCuser LCD recommendations:
https://forum.crystalfontz.com/showthread.php?s=&postid=1922
