CFAG16080A-YYH-TZ contrast circuit...
Ralpha
I'm looking at the datasheets for the CFAG16080A-TMI-TZ and the CFAG16080A-YYH-TZ. The circuits to control contrast are different, but the voltage requirements for powering the LCD are the same. How can this be?
For the CFAG16080A-TMI-TZ:
http://www.crystalfontz.com/products/16080a/CFAG16080ATMITZ.pdf
Vdd is connected to the top pin of the potentiometer
Vo is connected to the center pin
Vee is connected to the lower pin
For the CFAG16080A-YYH-TZ:
http://www.crystalfontz.com/products/16080a/CFAG16080AYYHTZ.pdf
The lower pin is grounded
It doesn't seem that the connection for the CFAG16080A-YYH-TZ would provide sufficient voltage to power the LCD? Is there an error in the datasheet?
Looks like a typo at first glance. I think the CFAG16080ATMITZ is correct.
I will ask CF Support to look at it tomorrow and find out if there is an error.
Ralpha
Thanks.
I also think the value for the expected negative voltage output Vee is incorrect.
It probably should be closer to -10 V.
Ralpha
I have a question about the LCD. The negative voltage output fluctuates a bit, which, in turn, causes the display to blink. I think the unit may be getting too much current. What do you think?
