I'm trying to make work together my LCD and my ATMega32 (on STK500), using an external crystal at 16MHz.
I'm planning to use code sources given right here, for my first test :
https://forum.crystalfontz.com/showthread.php?t=5042
I use Eclipse for coding. If I understand well, the only thing I have to do is to code the main source file, using functions given in low_lcd.c and others, correct?
If I'm right, could you give me please an example of what could be the main function?
Otherwise, would you show me the way to follow, from the beginning to the the end, to at last see something appears on my LCD display?
Thank you for help, I'm new in LCD and uC programming. At least I know C programming... ^_^
G.
G.
