CFAG12864B-TMI-V problems
tom
Dear All,
I am working on an application involving the CFAG12864B-TMI-V with a 16 bit micro. I am quite familiar with the micro, but have no experience with the CFAG12864B-TMI-V . I have spent the last couple of days trying to get the CFAG12864B-TMI-V to work but with no luck. I would therefore appreciate it if you could answer a couple of questions for me:
1. What are the operating voltages? I have VDD at 5.0V and assume that all the logic lines are running at 5V to (H). I initially had A (LED backlight +) at 5.0 but, after observing some serious flickering, concluded that this is supposed to be at 3.3V . Would you agree with my settings? What is the valid voltage range for K (LED backlight -)
2. What should I do with Vo and Vee? What are the allowable voltage ranges?
3. What is the write sequence for this device?
I have tried the following C++ code (part of a slightly larger class). I have used all of the basic components (I/O ports/port lines) in several previous projects so the only new factor is the CFAG12864B-TMI-V. My code looks as follows:
void WriteInstruction(TU8 byte)
TU16 i;
/* set E low */
Disable();
for(i = 0; i < 1000; i++);
/* set D/I low */
data_instruction_line->SetLow()
for(i = 0; i < 10000; i++);
/* set E high */
Enable();
/* set the DB0 to DB7 lines */
data_port->Set(byte);
/* set E low */
Disable();
void WriteData(TU8 byte)
TU16 i;
/* set E low */
Disable();
/* set D/I high */
data_instruction_line->SetHigh();
/* set E high */
Enable();
/* set DB0 to DB7 */
/* set E low */
Disable();
Kind regards
Tom
