Cfaf240320et lcd
Geetha
Hello tech
I am new to these crystal LCD.
I went through above mentioned LCD
what are the voltages for VCCI VCC2 VCCI in the interface diagram.
please send any documents regarding 8bit controller interfaced with CFAF240320et LCD.
please help me
Thanks and regards
Geetha.s
SmartB technologies.
Geetha
About LCD supply
Hello tech
Thanks for thr reply.
But from driver chip ILI9325 maximum on IOvcc is 4.5 ~6.0
which are the pins are taken out to connect these 3 supply pins(VCC1,VCC2,VCCI).
Where IM0 -IM3 pins needs to connect.
please guide me sir
I need interface 8 bit controller to CFAF320240ET TFT.
please suggest the interface precautions i should take
Thanks for the replies
Hello tech
Thanks for the reply.
please guide me sir
You should refer first to the datasheet for the LCD, not the controller, as the LCD datasheet will give the most insight as to how to connect the part to your microcontroller.
Please see the datasheet for the LCD on the same page as above, you will find the pinout on page 10.
