brainproxy
Hi!
I have opened a trouble ticket, but wanted to throw this out there to any linux guys who may be able to help me. I am fairly new to Linux, but I have a pretty good grasp. Here is the situation:
I can execute test 633:
brainbox root # /usr/local/crystalfontz/631_633_linux/test633 /dev/ttyS1 115200
Ultra-simple CFA-631 / CFA-633 / CFA-635 command-line communications example.
Usage:
/usr/local/crystalfontz/631_633_ linux/test633 PORT BAUD
BAUD is 19200 or 115200
Serial_Init:: tcgetattr() failed
Could not open port "/dev/ttyS1" at "115200" baud.
It is as if there is nothing connected to the serial port. I have tried this with ttyS0 - 7 just to be sure. Also with 19200 baud.
I have the CFA-633 serial connected with a 9 wire RS232 plug to my PC as well as the floppy power cable from my power supply. I recieve no life-signs from the LCD at all. Is this normal?
The cable I scavenged from a serial replicator port. I used a gender changer and plugged this into the PC so I could connect the cable.
I aligned the red wire to the "top" of the LCD so that pin 1 would correspond to wire 1.
The /dev/ folder holds ttyS0 and ttyS1, so I assume that they are valid devices.
I hope this information helps.
Thank you in advance,
Will
Usage:
Will
