CC2 fan control
Have a look at the "cc2-service\plugin_info\lcd_633.ini" file.
It is an example of how to setup fan control.
Forget about the lines that have "id" in them... they are not required for getting simple fan speed control working.
swedkg
tried that.
cannot find 633_stats.log to see if .ini is working. if i change fan setup in the .ini file and restart the service, the fans stop and start again, but they stay at 100%.
who can i see temps in the LCD?
________
buy volcano vaporizer
twistedmother
got the id recognised in the log but not the fans or the keypad modules!
not fussed about keypad but need fans
to work pls help
log file
Fri 24 00:51:49 NOTICE log_start: Logging started
Fri 24 00:51:49 NOTICE timer_calibrate: timer ticks/sec: 3192983664.3740
Fri 24 00:51:49 NOTICE ini_check_section: section found: module00
Fri 24 00:51:49 NOTICE ini_read_dword: value found: module00->id = 633022230
Fri 24 00:51:49 NOTICE ini_read_dword: value not found: module00->id_keypad
Fri 24 00:51:49 NOTICE ini_read_string: value found: module00->port = "\\?\ftdibus#vid_0403+pid_fc0b+5&328bcc6c&0&2#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73}"
Fri 24 00:51:49 NOTICE ini_read_dword: value found: module00->speed = 19200
Fri 24 00:51:49 NOTICE ini_read_dword: value not found: module00->key_repeat_rate
Fri 24 00:51:49 NOTICE ini_read_bool: value not found: module00->log_ntevent
Fri 24 00:51:49 NOTICE ini_read_string: value not found: module00->log_stats
Fri 24 00:51:49 NOTICE ini_read_bool: value not found: module00->fan_control
ini file
[module00]
;id for displaying to LCD
id=633022230
;id for keypad events
id_keypad=333939127
;keypad repeat rate
key_repeat_rate=250
;com port lcd is using
port=COM5
;com port speed
speed=19200
;log alarms to NT eventlog
log_ntevent=1
;log current status to file
log_stats="633_stats.log"
;fan setup
fan01_name=back
fan01_divider=2
fan01_sensor=0
fan01_lowtemp=20
fan01_lowspeed=25
fan01_hightemp=100
fan01_highspeed=50
fan01_alarmmin=100
fan01_alarmmax=10000
fan01_id_rpm=4224664230
fan01_id_lowtemp=3517082065
fan01_id_lowspeed=684980352
fan01_id_hightemp=374046237
fan01_id_highspeed=1242089502
fan01_id_rpmmin=2770399369
fan01_id_rpmmax=3939491725
;fan2
fan01_name=front
fan01_divider=2
fan01_sensor=0
fan01_lowtemp=20
fan01_lowspeed=25
fan01_hightemp=100
fan01_highspeed=50
fan01_alarmmin=100
fan01_id_rpm=2025277812
fan01_id_lowtemp=2146208151
fan01_id_lowspeed=2146208151
fan01_id_hightemp=2169479638
fan01_id_highspeed=1495925462
fan01_id_rpmmin=3093101512
fan01_id_rpmmax=2107301002
;temp sensor setup
temp01_name="CPU Temp"
temp01_alarmmin=5
temp01_alarmmax=75
temp01_id_temp=458828237
temp01_id_tempmin=1511380785
temp01_id_tempmax=1244121058
Certainly not an expert on this, but the first thing that looks odd is that you have comments for "fan 1" and "fan 2", but both sections are "fan01_*" names.
Shouldn't the second section be "fan02_*" names?
twistedmother
The stats.ini is in the same place as the log file C:\Program Files\CrystalControl2\cc2-service
folder but it aint much help cant seem to decipher it
Tue 28 13:51:19
CFA633 HW1.3 FW1.5
attached temp sensors: 1
sensor,name,rpm,rpm-min,rpm-max,speed,alarm-min,alarm-max,alarm-events,alarm-level
fan01,Fan 01,0,0,0,100,250,15000,0,0
fan02,Fan 02,0,0,0,100,250,15000,0,0
fan03,Fan 03,1697,1515,1723,100,250,15000,0,0
fan04,Fan 04,0,0,0,100,250,15000,0,0
sensor,name,temp,temp-min,temp-max,alarm-min,alarm-max,alarm-events,alarm-level
temp01,Temp 01,29.95,25.19,30.12,5.00,65.00,0,0.00
temp02,Temp 02,0.00,0.00,0.00,5.00,65.00,0,0.00
temp03,Temp 03,0.00,0.00,0.00,5.00,65.00,0,0.00
temp04,Temp 04,0.00,0.00,0.00,5.00,65.00,0,0.00
temp05,Temp 05,0.00,0.00,0.00,5.00,65.00,0,0.00
temp06,Temp 06,0.00,0.00,0.00,5.00,65.00,0,0.00
temp07,Temp 07,0.00,0.00,0.00,5.00,65.00,0,0.00
temp08,Temp 08,0.00,0.00,0.00,5.00,65.00,0,0.00
temp09,Temp 09,0.00,0.00,0.00,5.00,65.00,0,0.00
temp10,Temp 10,0.00,0.00,0.00,5.00,65.00,0,0.00
temp11,Temp 11,0.00,0.00,0.00,5.00,65.00,0,0.00
temp12,Temp 12,0.00,0.00,0.00,5.00,65.00,0,0.00
temp13,Temp 13,0.00,0.00,0.00,5.00,65.00,0,0.00
temp14,Temp 14,0.00,0.00,0.00,5.00,65.00,0,0.00
temp15,Temp 15,0.00,0.00,0.00,5.00,65.00,0,0.00
temp16,Temp 16,0.00,0.00,0.00,5.00,65.00,0,0.00
temp17,Temp 17,0.00,0.00,0.00,5.00,65.00,0,0.00
temp18,Temp 18,0.00,0.00,0.00,5.00,65.00,0,0.00
temp19,Temp 19,0.00,0.00,0.00,5.00,65.00,0,0.00
temp20,Temp 20,0.00,0.00,0.00,5.00,65.00,0,0.00
temp21,Temp 21,0.00,0.00,0.00,5.00,65.00,0,0.00
temp22,Temp 22,0.00,0.00,0.00,5.00,65.00,0,0.00
temp23,Temp 23,0.00,0.00,0.00,5.00,65.00,0,0.00
temp24,Temp 24,0.00,0.00,0.00,5.00,65.00,0,0.00
temp25,Temp 25,0.00,0.00,0.00,5.00,65.00,0,0.00
temp26,Temp 26,0.00,0.00,0.00,5.00,65.00,0,0.00
temp27,Temp 27,0.00,0.00,0.00,5.00,65.00,0,0.00
temp28,Temp 28,0.00,0.00,0.00,5.00,65.00,0,0.00
temp29,Temp 29,0.00,0.00,0.00,5.00,65.00,0,0.00
temp30,Temp 30,9556.94,9556.94,9556.94,5.00,65.00,0,0.00
temp31,Temp 31,0.00,0.00,0.00,5.00,65.00,0,0.00
temp32,Temp 32,0.00,0.00,0.00,5.00,65.00,0,0.00
well ive got 2 temp sensors and thats looks right but logile still says module not found for fans and temps !
Maybe it might be an idea to post what you did. It may help people who are looking for the same information now or in the future. I don`t have a 633 module, but if I consider getting one in the future, then this would definately be something I`d look at.
A little bit about your setup and what you are trying to achieve would round it off nicely. This is assuming you have the time to do it.
Steve
twistedmother
Here you go folks
Phew i did a lot of playing & experimenting to get this to work so excuse me if i miss something as the log file moaned i added the entries
in your "C:\Program Files\CrystalControl2\cc2-service\
Lives lcd_633.ini
Open this file and paste below DO NOT OVERWRITE AS YU WILL NEED TO ID's
[module00]
id=633022230 (Change this to your modules ID)
id_keypad=333939127 (Change to your keypads id)
port="\\?\ftdibus#vid_0403+pid_fc0b+5&328bcc6c&0&2#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73}" (change to your port)
speed=19200
key_repeat_rate=250
log_ntevent=1
fan_control=1
fan03_name="back"
fan03_divider=2
fan03_sensor=01
fan03_lowtemp=37
fan03_lowspeed=25
fan03_hightemp=40
fan03_highspeed=100
fan03_alarmmin=100
fan03_alarmmax=10000
fan03_id_name=4224334234
fan03_id_rpm=4224664230
fan03_id_lowtemp=3517082065
fan03_id_lowspeed=684980352
fan03_id_hightemp=374046237
fan03_id_highspeed=1242089502
fan03_id_rpmmin=2770399369
fan03_id_rpmmax=3939491725
;fan2
fan04_name="front"
fan04_divider=2
fan04_sensor=01
fan04_lowtemp=20
fan04_lowspeed=25
fan04_hightemp=39
fan04_highspeed=100
fan04_alarmmin=100
fan04_alarmmax=10000
fan04_id_name=4444334234
fan04_id_rpm=2045277812
fan04_id_lowtemp=2146208151
fan04_id_lowspeed=2146208151
fan04_id_hightemp=2169479638
fan04_id_highspeed=1495925462
fan04_id_rpmmin=3093101512
fan04_id_rpmmax=2107301002
;temp sensor setup
temp01_name="Dallas1"
temp01_alarmmin=5
temp01_alarmmax=75
[module01]
id=1177071336
port="\\?\ftdibus#vid_0403+pid_fc0b+5&328bcc6c&0&2#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73}"(Again change this)
speed=19200
*Remove all duplicate entries
*Delete all the stuff in brackets (change this to your..."
*Fan no's correlate to fan headers on 633 panel
* check log file in the same folder lcd_633.log
* Not sure if this mattered but Uninstalled MBM
the ID numbers have to be unique as they can be used in a screen plugin but otherwise there is no need to change them i created a screen showing temp sensors but cannot get an average fan speed on the display not RPM's (ie runnning at 40%) anyone any ideas ?
Many thanks twisted, I`m sure people will find the information useful. Someone who has the 633 module may get back to you on the screen problem.
I`m interested in the keys too, did you get those working? I realise initially you weren`t interested in them too much but wonder if that has now changed. I see they are listed in the lcd633.ini i tried them in my lcd631.ini but not too sure of the correct ID number yet.
Steve
twistedmother
For your info the keys are recognised in the log file although i have not set anything to use them, i think it's safe to assume once the log fle picks it up it's ok
