Hi
I'd like to get a 635 to use a display device in my lounge. However, I plan to interface it to a TINI microcontroller which does not have a USB connection.
Can the 635 and SCAB be used with a serial connection in any way? Looking at the block diagram, the USB controller is external to the microcontroller, so I assume the two communicate via a serial connection.
If so, could the usb controller be removed and a level shifter chip fitted to allow RS232 connection?
I am happy to make up custom cabling to or solder the board to make this work.
Alternatively, could the GPIO pins be used to create a serial connection, as discussed in another post?
Thanks in advance for any help,
Simon
Simon
