I have the CFA634-YFH-KP LCD display. I would like to change the boot screen. I changed the interface from SPI to RS232 by sending command \009\002\001 through SPI. And I set the jumper as the following:
JP3, JP4 - open
JP5, JP6 - closed
JPC, JPD - closed
JP2 - open
JPBL - clolsed
JP_DB9_PWR - open
JP1 - open
The 5V power is provided on J2. I tried to use cftest to send some commands in order to see if the LCD is able to receive commands from RS232. I didn't change the baud rate (default 19200). Tried to adjust the brightness and contrast and nothing is changed on display. Also tried to use Boot Setup to config the boot screen. Hit "Update" and "Store all setting to EEPROM" but nothing shown on the display.
What else I need to do to communicate with RS232/Boot Setup? Can I just config the boot screen without changing the interface and sending commands through SPI with no software?
I appreciated if you could help on this issue.
JP3, JP4 - open
JP5, JP6 - closed
JPC, JPD - closed
JP2 - open
JPBL - clolsed
JP_DB9_PWR - open
JP1 - open
