Bezel/trip for 634 or 632
JamesF
Hi all,
I'm planning on mounting a 634 (or possibly a 632) in the side of an aluminum PC case. It's difficult to cut perfect holes with a Dremel, and I was wondering if either of these units come with a bezel or trip piece for fitting into a hole. Perhaps something that slips in from the front and overlaps the case just a bit to hide imperfections in the cutting.
Please let me know if I haven't explained this well.
Thanks!
James
I suppose we could sell you just the plastic overlay from one of the brackets. You could cut the outside dimensions to your liking and then stick it in place. I am not sure that a hand cut edge on the overlay would look nice enough--maybe wiith some careful sanding?
JamesF
Bezel/trim piece
That sounds like an interesting idea. I've got plenty of tools that might make this process easier than cutting a perfect rectangle in the aluminum. Can you point me to a picture of the part you're talking about?
James
It is a plastic "lens" or overlay stuck to the front of out metal brackets:
More pics here and here.
JamesF
Ah ha!
I like the 634 unit the best, but the overlay is white and rather large. I'm thinking I could make the black overlay of the 632 work well, as I'd only have to trim the sides a bit and leave the height alone...
James
