HI there
A couple of question to set my mind on purchase.
Im after a LCD which can be viewed in sunlight(inside motor vehicle) and also at an angle 90+deg
I am after a 4X20 serial or parallel interface HD44780 compatible.
- What do u recommend?
CFAH2004L-NYG-EP(large characters) or the 634? What will be more clear in sunlight.
- Also if I use the CFAH2004L-NYG-EP in 8bit parallel would the refresh rate be sufficient on a 5m cable? OR is serial the only way to go with this long length.
- What is the best color combination of the backlight for visibility?
- I noticed u sell 2x16OLAP modules any chance u do 4x20? 4x16?
- Lastly Is it true that OLAP screens outperform LCD’s when it come to visibility in sunlight/and angles?
