Howdy!
Brand new with LCDs, I just wanted to ask a few very basic questions (I'm using the CFAH2002A):
For intialization using the 8-bit interface, I'm looking on page 16 of the datasheet.
The first "string" I have to send out is 0 0 0 0 1 1 * * * *
In fact, I have to send this out 3 times for proper initialization. Can I just hold this string on the pins for ~20 milliseconds? Why is it listed that I have to send the string three successive times? What pin do I use to "strobe" each string?
In the "entry mode set" instruction, what are pins DB1 and DB0? They are labeled as I/D, and SH, but what do these mean?
In both of the read and write operation timing diagrams, the E enable signal is returned low "somewhere" during the DB0-DB7 valid data changes. Is the E pin like the "strobe" pin used to tell the LCD when to sample the 8 data pins?
Thank you very much!
-RT
-RT
