Bar graph
NiTRo
Is it possible to include in CC a function witch permit to display a bar graph.
for example, instead of display a value for network DL or UP i wish i can display a bar graph to "see better" :D
I know what i mean ?
Regards
Savona
I Agree
I have looked all over the web for a program that will do bar graphs and do them well. I think this should be in the next release. Thanks
NiTRo
But...
I hqve try to install and use it but it neer work with my CC, even if the author of the soft tell that he include a "native support" for CC but...
any ideas ? someone use it ?
Americanfreak
I use it.....if you have a serial LCD put in what com port you use.....like com2 and save the config. Reopen the config and you should be ready to go.....
Americanfreak
I have the CFA634-YFB-KS LCD
and I think it works great......bargraphs. moving icons, plugin's etc....
My little yellow box at the bottom of my messages is from jaLCDs...it updates my system info every 2 minutes to the screen... ;)
NiTRo
But when i try to use it, it doesn't work good : flashing, not displya right things...
you have the last version ? with specific plug for CC ?
Americanfreak
NiTRo- I am using this version jaLCDs 3.1 .
Kevin- I will send you my config, with email stuff removed, and you can give it a try and a look over. I am using some custom characters.
The sig thing is something that you also have to setup at the jaLCDs web site. under "Community Area / Stats Center". You do have to register to gain access but you get to see all the custom charters and a whole bunch of other peopls configs.
