Ok, I just received my CFAH2002A-YMC-JP 20x2 module and now I need to think about wiring it. I found lots of useful stuff throught the forums, most of which I have printed for more detailed review. This leads to the following questions:
Backlighting: most of the more complex information that I have printed relate to this particular area. Can I, for the purposes of getting it up and running, ignore the backlighting connections and just do everything else?
If yes to above, how readable will a reverse backlit green/black screen without the backlight?
I take it from the forum discussions that I could bypass the potentiomters and just use a resistor on the +5V line. If this is the case, what size resistor have you found works for a reasonably clear display?
I take it that Pin 1 and 2 provide ground and +5V power for the unit itself and not for the backlighting. Do I simply connect the +5V and ground wires from a molex connector to achieve this with no resistors or any other components?
The diagrams indicate that Pin 15 is LED+ (A) and 16 is LED- (K). But what is the A and K connectors on the opposide end of the LCD PCB (also has "5V" written on it)? Which one is the correct one for supplying power to the LCD backlight? Or do I need to do something with both?
Many thanks....
Many thanks....
