Animated SCAB Graphics Screens
Well, I've finally got around to adding an animated graphic to some SCAB screens.
The screen attached here is for a 635. Includes screen outputs for 4 fan speed %'s. The graphic, of course, is a fan. Default directory, as usual, is C:\gifs.
I set the fan names to a fixed length of 7 characters. Change it if you need to.
If you have less than 4 fans, simply edit to remove the appropriate lines.
Jim
Now with a new and improved animated fan!
  • jc_scab-fans-ani-635.zip
The screen attached here is for a 635. Includes screen outputs for 4 temp sensors. The graphic, of course, is a thermometer. Default directory, as usual, is C:\gifs. BTW, no jokes about the animation!
I set the temp names to a fixed length of 6 characters. Change it if you need to.
If you have less than 4 temp sensors, simply edit to remove the appropriate lines.
Jim
  • jc_scab-635-temps-ani.zip
The screens (#1 for the 1st 2 fans, #2 for the next 2 fans) attached here are for a 633. Includes screen outputs for 4 fan speed %'s. The graphic, of course, is a fan. Default directory, as usual, is C:\gifs.
Edit the files if you have 1 or 3 fans.
Quite easy to change to a 631 by renaming the files to .cfa631 and editing the cols=16 to cols=20.
Jim
  • jc_scab-fans-ani-633.zip
The screens (#1 for the 1st 2 temp sensors, #2 for the next 2 temp sensors) attached here are for a 633. Includes screen outputs for 4 temp sensors's. The graphic, of course, is a thermometer. Default directory, as usual, is C:\gifs. BTW, no jokes about the animation!
Edit the files if you have 1 or 3 temp sensors.
Jim
  • jc_scab-633-temps-ani.zip
I like.
I have a 633 installed on a simple water cooled rig. 3 probes sample water temperature in and three probes water temp out.
If I wanted screen 1 to show probes one and four, and screen 2 to show probes two and five, exctly which lines might I edit in the screens?
anonymous_putterer said:
I like.
Try this one.
Jim
  • jc_scab-temps-ani.zip
