Access violation in simulated LCD
tellis100
I'm getting the exact same error message on my system.
"Access violation at address 0049f234 in mode crystalcontrol.exe read of "address 00000000"
I get this when I try to add a screen.
My specs:
Windows XP Pro w/SP1
Crystalcontrol 0.99
MBM 5.20
632 display
I installed the .NET framework like a previous post mentioned but it didn't help.
I tried 0.98 and get a similar error message but at a different register address.
resalution
yeah its getting really frustrating. Its a hot ass lcd but if the software deosnt work i might have to switch to matrix orbital. And u dont wanna see that happen. by the way Admin can i return the lcd if the software deosnt work?
Hang on fellas, a new version will be coming shortly.
There is a lot of other software you can try if you dont want to run CrystalControl.
LCDC, LCDSmartie, JalLCD, etc.
resalution
thanks admin i will remain truthful to crystalfontz. Keep up the good designs. You will have a booming business in the near future.
resalution
Weird thing i found out was that when i run Wintest it says "at COM 1 19200" I run it again and it says COM2. running several times it varies. i load up a default screen from the Crystalcontrol folder and it seems to show up only when i select COM3. All the other ports when selected wont show anything except the backlight. And when i change the contrast nothing happens to the screen. See if u guys have the same problem.
mr.cool
hi YAY only version 98 work without errors
i have installed xp with sp1 new
then i installed crystal control 99 (the same error )
only 98 work and works and work
