1) Can I connect to that display a temp. sensor like to the 633, directly or do a little wiring?
2) will it fit in a 5.25" drive bay with drives both on top and below? if not then in two floppy drive bays?
3) is there a way to wire a button to it so when i press the the button it will display different things (only two modes is enough, like a toggle button. i.e. if i display temp. of stuff in one mode, when i press the button it will display fan speeds and vice versa)?
4) Is there an installatoin guide for that particular diplay?
5) Why are the dispalys that connect to the serial port better than the ones that connect to the parallel display (I think that they are better cause they cost more)?
By the way you have really great and helpful forum.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
