Greetings-
Is there a way to disable the ability to power-down or reset ATX control from the front-panel of a 635+SCAB?
I would like power on, USB-control and Watchdog to work as designed but if the system voltage sense is high don't allow input from the keypad to control ATX power.
I am working on an appliance like system. Even if I have to loose power on I'd be ok but I need watchdog and for security reasons I don't want the user to have powerdown/reset.
I assume the worst-case would require new firmware. best-case would be a config option I can send via USB.
