BlancMange
Hey guys, me again
just another question...
is it possible to program the LCD using its on board memory / bootrom to do the following scenario:
im looking at getting a phase change unit built by kayl (if you have heard of him), just a basic one without a controller....
im wondering, can i use the 635 + scab so when i press the tick on it, it will boot the compressor (relay on a GPIO or somthing) and then once the temperature reaches the desired value (-35 deg cel for example) it will then boot the pc and once windows is loaded act like a normal CF lcd with CC2.
so heres the events i was thinking of:
press Tick
Relay engages (using a flipflop to toggle the relay or somthing like that, so the LCD just needs to pulse the GPIO once)
compressor turns on
desired temperature is reached
LCD boots PC.
Windows loads, and CC2 initializes the LCD
then, as another question on top... if that is possible.... if i press the tick to start the cycle, and i want to stop it (e.g. turn the compressor off before it reaches the desired temp) by pressing the X, it just cancels the cycle and turns the relay off.
is that even remotely possible.... as otherwise i will have to turn the compressor on manually, watch a external temp sensor, then boot the pc manually....
thanks in advance
-matt
press Tick
compressor turns on
LCD boots PC.
thanks in advance
-matt
