USB LCD CF-633 under Linux
Hello all,
I am new in the LCD experience so I know nothing about it !!!
I would be interested in a USB 633 but I just want to know if the single USB cable is enough or if we need to connect an cable for power to make it work under Linux ( Debian 2.6.5 ) that support the driver for USB and i have configure LCDproc 1.4.4 with:
[CFontz]
# CrystalFontz driver
# Select the output device to use [/dev/lcd]
#Device=/dev/ttyS0
Device=/dev/ttyUSB0 ##
# Select the LCD type (size) [20x4]
#Size=20x4
Size=16x2 ##
# Set the initial contrast [140]
Contrast=140
# The backlight brightness settings are retrieved
# from the serversection now. And can therefore be
# modified from the server menu now.
# Set the communication speed [9600]
# possible values: 1200, 2400, 4800, 9600, 19200
#Speed=9600
Speed=19200 ##
# Set the firmware version (New means >= 2.0) [no]
# if set, set Speed to 19200
#NewFirmware=no
NewFirmware=yes ##
# Reinitialize the LCD's BIOS [no]
# normally you shouldn't need this
Reboot=no
# This is using the USB->serial driver [no]
#USB=no
USB=yes
but the CF-633 dosen't work!!!!!!!!!!
if someone can help a poor guy (such I am) it would be very very nice
Thanks a lot
jwegman said:
I was having the same "lock up" problem with lcdproc 0.4.4 cvs (12-30-03) with Gentoo running the gentoo-sources 2.4.20 patched with Wayne Wylupski's kernel driver patch (adds the Crystal Fontz USB IDs).
I then updated to the gentoo-dev-sources-2.4.23 which already had the CF USB ID's and the problem still occured.
I then "down graded' to the vanilla-2.4.20 sources with Wayne's kernel driver patch and now my 634 usb v2 functions with lcdproc 0.4.4 cvs mentioned above.
Jake
