If i was to get a 634 USB like so: (CFA634_TFB_KU)
Its got a back that looks like this:
1: Does the addon board for usb stick out past the COM port header ? or is it basically the same profile ?
2: Does running it thru USB require a single dedicated USB port on the mobo header ? Some MS keyboards were USB and had 2 additional USB ports on the kb, so you could use it as a mini-hub of sorts. any ideas about this ?
3: concerning CF Tech's post here:
https://forum.crystalfontz.com/showthread.php?threadid=3368
What LEDs are used for backlighting (if you care to tell me / us) ?
Would they happen to be a 0603 / 0805 / 1206 LED ? If not, what is the tollerance thats accecptable to use ?
4: Also about backlighting, im guessing 634USB backlite is software driven. Is there a connection between the usb board and the main LCD PCB where this could be manually manipulated, such as a manual on-off switch ?
Cheers for any advice that you can give to me![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![](http://www.crystalfontz.com/products/634usb/CFA634_TFB_KU_Backlight_On.jpg)
![](http://www.crystalfontz.com/products/634usb/CFA634_USB_Back_Outlined.jpg)
