ScottishCaptain
Greetings to all!
I am currently working on a highly customized embedded "demo" PC for a client. Sofar the unit will contain a 635 USB LCD to display formatted system stats, however, I am also looking for a LCD to display general serial output from some low-level software.
In particular, I need to display the output from the bootup firmware on a Serial device of some sort, as well as Linux based console text via a standard terminal (VT100 I believe).
The display I'm looking for should understand VT100 Line Feed and Clear Line/New Line commands, and thats about it.
Does anyone know how the 634 Serial LCD's handle commands? Could a 634 unit be used (Serial) as a small 4x20 Pseudo-VT100 simplistic display- as in, is the 634 command set similar enough that it would understand the basics- new lines, clear screen, etc?
Or would something like this require a custom firmware? How much would it cost one to purchase a 634 with a custom firmware designed to allow the 634 to act as a VT100 semi-compliant Serial "Terminal"?
Thanks!
Thanks!
