Greetings...
I just installed my 631, I might add, without a hitch, and it works great for my needs, which is primarily as a systems monitor. Using CrytalControl and MBM, I can monitor just about anything I desire, no problem. I do have a usual noob question regarding the keypad. Is is possible to access the keystrobe lines, say for use in controlling something? What I have in mind is using the strobe to toggle a flipflop, which in turn, will either turn on, or off, and control device, like a relay, for instance, using a driver transistor. I noticed a connector which isn't mentioned in the pdf file, that I am hoping might let me access the signals I'd need to pull this off. I imagine this connector would be where the expansion module for fan control and temp monitoring would connect, then again, this is merely supposition on my part.
Speaking of the module mentioned above, I'll be among the first to order one once they become available. I can think of several temps I'd like to monitor that my present hardware just isn't capable of, and to have that in addition to the amount of things I can already keep an eye on, would truly be the icing on the cake. Outstanding product, service, and delivery. A big slice of happy pie to both CF, and FedEx.
Belgarius
Belgarius
