thomas_d_stewart
I need a 40x4 display.
The CFAH4004A-YYB-JP (http://www.crystalfontz.com/products/4004a/index.html) seams good. But could I get some infomation on how to hook it up. A web page or anything. Or is it as simple as the pdf spec says, and just use the normal paralel lines? It preferably needs to be usb. So do serial/paralel to usb adapters work well?
Also if its paralel how fast can the display update? Would there if a differance between it and the high speed serial ones?
I already have a serial lcd (4x20) and I like its features. As this is not a serail one, can I still controll the backlight with software? (I Asume that its too simple to have startup text and the like?)
I would prefare to use cryatalfontz as I like the company, but if anyone knows of a good suplyer of a 4x40 with a black on blue backlight display, non-flicker, fast refresh, seral interface and an easy way to hook it up. I would be very greatfull. I'm begining to think the perfect display does not exist, hence asking about this green 40x4.
Much Thanks
Thomas
Much Thanks
Thomas
