20x4 question
archon
I would like a 20x4 ( CFAH2004A-YYB-JP 20x4 Array LED Backlight ) with a mounting bracket in beige that takes 2 bays with all the cables i need to cleanly mount it on the back with a serial port and a cable to connect from the back to my serial port like in the WR232Y09 and WR232Y10 if that makes any sense.
How much will this all cost?
btw, what is the biggest LCD i can get for 2 5.25 bays? is the 20x4 the biggest?
The CFAH2004A-YYB-JP is intended for embedded systems (not PCs) and will not fit in any of the brackets we sell.
Please consider the PDBK634LG, which is serial.
archon
That package has everything i need correct? I won't need to buy anything else to make it work.. right?
archon
archon
ah ic.. kinda small though.. when you mount a 16x2 in the bracket with those buttons can you store like multiple stats? example:
LCD 'Uptime: 1h2m1s'
press down button and see
LCD 'IN: 245kb/s'
LCD 'OUT: 349kb/s'
and press down again to see
LCD 'OS: Windows XP'
Is that possible?
The hardware supports all that. We are working on software support for those kind of operations.
