quick answer: make sure .net framework 2.0 is installed
symptoms:
Check event viewer->system section for these errors:
should be a series of 3 each time you try to start the service:
1) Dependent Assembly Microsoft.VC80.CRT could not be found...etc
2)Resolve Partial Assembly failed for Microsoft.VC80.CRT...etc
3)Generate Activation Context failed for C:\Program Files\CrystalControl2\cc2_service.exe.
these events usually correspond to the message that was something like "bad configuration. try reinstalling app" (can't remember exact wording)
cause:
no vc80 library support
fix:
make sure .net framework 2.0 is installed.
this was my problem and the fix worked for me. i'm not totally sure regarding other cases.
-R
symptoms:
cause:
fix:
-R
