I hope this is the correct forum.
I'm designing some hardware using the CFAX12864AP1 module (beautiful little unit). Before I get too far on the prototype, though, I wanted to verify some things. I want to use the unit in Serial Mode. In this mode (P/S=0) what would be the appropriate settings for the other pins? DB0-DB5 become high impedance, but high-Z inputs or outputs? If inputs should they be tied to Vcc/Gnd? If so, what would be an appropriate value for the pull up/down resistors? In fact, is it be okay to tie any signal pins directly to Vcc or Gnd or can you recommend a pull-u/d resistor value? Also, what is the best thing to do with the MI pin in serial mode? I assume it is meaningless and can be tied either hi or low?
I've looked through the controller spec and it seems that it would be possible to drive the unit serially using an SPI bus. Does anyone have any advice as to how this should be done? I have seen that it is recommended that byte boundaries be indicated by toggling the CS pins which would work well with the SPI bus and the timings/signalling are compatible.
Thanks in advance for your help!
