Hi there,
i have three 635 with a SCAB attached. I want to use them for 19" 1U computers to show IP-Adress, Bitrate, temperatures etc.
I have connected the SCAB with the ATX-cable (WRPWRY14) to the motherboard.
I have set the GPIO pins to ATX Power functionallity using command 28.
Then i have configured my boot up screen with the 635 Wintest programm from your homepage.
In the next step i configured the atx functions no. 1, 2 and 4 (Reset, Power on and LCD off when host off) using command 28 as well.
Now everything is fine. I can boot up the machine, reset it and the display turns off when the host is off.
My problem is when i turn on the machine with the check button of the display it starts and the boot up screen from the 635 display comes up but the backlight is off. When i configured it as boot up state it was set to 100%.
Why doesn't it come up with the backlight at 100%, the rest is working fine?!
Thanks for your help...
Ralf
Ralf
