CFAH2002A-YYB-JP connected via parallel to a PC.
It works on 1 other PC no problem, BOTH in DOS mode using LCD print....
PC it's working on:
Pentium III Compaq PC, DOS mode, LCD PRINT or the CrystalFontz debug program. It works just fine, port in ECP mode.
PC it's not working on.
Pentium 4, Clone PC, LCD PRINT or CrystalFontz debug both don't work, (yes i've installed the driver, it's running XP but I tried the dos app too), tried the port in ecp, epp, spp, ecp+epp no dice, the LCDprint app DOES see the port but not the display and it doesn't print anything
Any ideas???? WEIRD... A Printer does work on this PC I have tested the port and it works fine........ I suppose the next step would be to get a meter and see if it's throwing command codes out.
PC it's working on:
