Wiring information needed for CFAG128128B
Status
Not open for further replies.
kasunt
Hi guys,
I followed the wiring diagram on the datasheet closely. I'm wanting to connect the LCD to a MCU like AVR or PIC.
What is the purpose of having an external contrast adjustment if there is already circuitry internally to adjust the contrast (Ref. page 8 of datasheet) ?
And what is the required value for resistor B/L drive circuit ? (Ref. page 14 of datasheet)
Thanks in advance.
CF Support2
The CFAG128128B family has an onboard negative voltage generator - but you still need to connect up Vo so that it can be driven and the contrast adjusted. The simplest way is to use a 10KΩ to 20KΩ pot across Vcc (+5v) and Vee (NVG out), with the wiper to Vo (contrast).
Since the backlight LED characteristics are the same for the white and yellow-green LEDs, the same current limiting resistor is calculated. You use the voltage dropped by resistor in the circuit:
Typical current = 80mA
Forward voltage of LEDs = 3.5v
Supply voltage = 5v
V / I = R
(5 -3.5) / .080 = R
1.5 / 0.80 = R
1.875 = R
For power rating:
I*V = P
0.080 * 1.5 = P
0.120 = P
The minimum you would want to use would be a 1/4W 1.875Ω resistor.
kasunt
Thanks a bunch for this.
So you dont really require an external circuit even though the datasheet mentions it ?
kasunt
Supply voltage = 5v
V / I = R
(5 -3.5) / .080 = R
1.5 / 0.80 = R
1.875 = R
For power rating:
I*V = P
0.080 * 1.5 = P
0.120 = P
And I think you made a mistake with the calculation. It should be 1.5 / 0.08 ~ 18.75Ω
CF Support2
Yeah, I got carried away with my zeros :eek: - I was testing you... yeah... testing you... that's it.
All you need is a pot, or some other way to control the bias voltage. The module has the circuitry on-board to get you the voltage you need. Your job is to get it there!
Status
