olivialees12
Just bought my new Crystalfontz display and was taking a look at the HD44780 wiring guide included with the Crystal Contol software.
For wiring up the power, the guide says:
Solder a moderatly long piece of black wire from pin 24 of the DB25 connector.
But the wiring table shows ground being wired from pin 25.
And also, my parallel cable only has 18 wires, pins 18-24 aren't connected to anyting.
So should I wire ground to pin 24, or 25?
Also, the wiring guide for the 100 Ohm pot only describes a connection from pin 2 and pin 1(or 3). Do I just cut off the other pin?
Thanks for the info.
Mike
Mike
